New D-BOX Game: Gran Turismo 7 🏎️
Summary
So happy play GT7 with D-Box, thanks for sharing this information. Use VR2 together, pretty dope experience.
This is fantastic news and I would like to thank you for this effort.
Just tried and it wors well.
I just wonder if there is a way to change the Port where the app is listening.
I use SimHub for a belt tensionier at the same time and this app may fw. the data to another UDP Port.
THank you!
Christian
SimHub stops working with this on? Thinking of adding a GSeat/GBelt to my D-Box rig…
Hi Michael!
Well, not realy. But every App needs his own UDP Port.
In SimHub, you may take the data and foreward it so another Port.
And this was my question. How to make sure, D-Box listen to another Port.
Adding the port in the field liet 192.168.0.100:33374 doesn’t work. But I’am sure, we will find a way.
BTW: this is only because of the PS5 / PC stuff where the Apps try to grap the data from out of the network protocoll. In IRacing atc. this is not an issue. I use the Belt (SimHub) on my D-Box Rig.
Just did my first 60min Race.
Motion Realisation is fantastic.
Having the ABS Signal would be great as an update.
And - as mentioned - a field to chose UDP Port.
Thanks again to the D-Box Team
We are so happy you enjoy it!! Thank you for your Feedback!
Wow! Thank you for sharing, we love seeing you enjoy our products!
what am I don’t wrong, I can’t find the game in my game list. I updated the list. I’m still running Game Center 4.2 (20496) is there a newer version?
When you open Game Center, an updated list will pop up very quick at the bottom right corner. Don’t miss the chance, good luck.
Hello Jon!
It is indeed necessary to update the Game Center to version 4.2 (20500). As mentioned by vance_tsai@me.com, a pop-up notification will appear. However, the update can also be found in the Windows Tray.
Let us know if you are able to access the game ! :slight_smile:
Thank you. I was able to finally get it updated. This game feels so good with the DBOX settings. I have a DOFreality H6 with SimRacingStudio software before for GT7 but this is AMAZING the coding is great for motion and haptics. It makes me want to get the Logitech PRO racing wheel to get TRUEforce to add to the immersion for this game. I do have the Fanatec CS DD+ on order… but that is a whole debockle in itself…
Can we expect to see the ability to run applications like SIMHUB in tandem with DBOX in the future? I would love to have my digital dashes and wind sim working with this motion setup.
I also found that D-Box’s fidelity is amazing compared to the other motion platforms that I’ve tried before my purchase, and now we’re seeing more frequent additions in terms of game support and adaptive game profile improvements, I am hopeful for the future enjoyment of my D-Box sim rig!
That being said, I am looking at adding a G-Seat / G-Belt to my sim-rig for some persistent g-force simulation, and also hoping like you that it can play nicely with the D-Box software, but I think a bunch of people with G-Seat also has it working with their D-Box rig…
Thank you for your feedback! We have informed our team of your request regarding the ability to run applications in tandem with D-BOX and we will get back to you when we have more information on the subject! :slight_smile:
I was pleasantly surprised to see this profile released, and it works really well with a high level of detail coming through. Congrats d-box team.
Just one bit of feedback: in other simulations the front to back pitch mainly comes from weight transfer (braking etc.) with a small effect from pitch changes in the road (going uphill). But in GT7 it seems the opposite way around with pitch dominated by road elevation, and only a minor impact from braking. You get used to it but I was wondering whether it could be adjusted. Thanks!
Thank you for your feedback. We will transfer the information to our team and keep you updated! :slight_smile:
Does that mean that to play GT7 on PS5 I don’t need a subscription to HaptiSync?
Hello Michel,
You don’t need a HaptiSync subscription, but must have a D-BOX Connect account. You can install the Game Center, and follow the instructions to connect his PC to your PS5. You can find the instructions directly in the Game Center, and here : https://support.d-box.com/en/knowledge/how-to-activate-d-box-haptics-in-gran-turismo-7
Merci Frédérique. Does this apply to all the games on PC?
Yes, this is applicable to all D-BOX supported games. You can refer to the catalogue to access them all: Games - D-BOX Catalogue
So I played around with it a lot with the controller. I must say it’s a little disapointing compared to Forza Motorsport motion codes. What I see that needs improvement.
  1. There seems to be missing traction control loss.
  2. No ABS function to feel the car tire chatter
  3. Elevation is tied to the geometry of the track instead of brake dive from car braking. (I actually like this as it feels better to me, but would be better to have both options)
  4. The motion profile editor doesn’t work correctly. I can turn everything down to level 5 and it feels the same if it was on 40.
  5. To correct the above I turn the Main level to 40% and then leave the motion editor at default 40 so it’s not overpowered. Then I have to turn up suirface texture to 50 to feel that better.
  6. The motion like the guys video above is not smooth feeling like it is in Forza or AMS2 etc. It seems to feel like it’s bottom out in when it still has more travel in the actuators.
Here is a video I did to show the difference: https://youtu.be/EWKhKkKkRm8?si=yQSsz_q2n9RiYTzv
Also if you want to now how to get it to work here is another short vid: https://youtube.com/shorts/VyFErBhbxSU?si=2EM0lQFcKiFhmxFZ
Is there a new update coming soon? This is pretty basic compared to other sims.
Thanks
